zumo xt freeze when using function in maps
hotacid
Slovenia
Post by hotacid »
Hello,
After software update I have problem with freezing zumo xt. I have software version 6.4
When I lunch Show map, the map normally show. But when I click on three dots in down right corner, the device freeze and restart automatically.
Do any have such a problem? What I can do? Thanks for your replays and suggestion!
Fallguy67
Has liked: 44 times
Re: zumo xt freeze when using function in maps
Post by Fallguy67 »
I am having the same issue.
hotacid
Slovenia
Post by hotacid »
I have checked the forum and I saw that was already discussion regarding this problem with new update 6.4. I did restart my garmin zumo xt to previous 6.3 software and reinstall updated with garmin express program. Now it works.
simoncrewe
Has liked: 46 times
Been liked: 37 times
Post by simoncrewe »
Most people with this issue, find that a factory reset fixes this problem.
Seldano
Post by Seldano »
Yeah, just had to do a factory reset on mine to fix this.
pjotr
Post by pjotr »
Firmware 6.5 solves thuis issue.
