7.13.1.0 already
groundhog719
Has liked: 12 times
Been liked: 5 times
7.13.1.0 already
Post by groundhog719 »
1 day after 7.13.0 and already 7.13.1 is out!
Has liked: 378 times
Been liked: 384 times
Re: 7.13.1.0 already
Yep, hoping it'll allow me to install map to my PC as 7.13.0 wouldn't
Raf
Has liked: 16 times
Been liked: 3 times
Italy
Post by Raf »
sussamb wrote: Fri May 20, 2022 6:42 am Yep, hoping it'll allow me to install map to my PC as 7.13.0 wouldn't
Work?
Yes
Raf
Has liked: 16 times
Been liked: 3 times
Italy
Post by Raf »
I did not find the option "Install only on PC".
I have Basecamp version 7.13.1.
I did it like this:
I used the BMW Nav VI, Garmin Express with this navigator allows you to install the maps even only on PC.
I updated with the wifi the zumo XT.
After I installed the 2023.10 on the XT I reconnected it with USB cable to the PC. And only at this time I have the option to install "Pc Only".
Mystery
electro_handyman
Been liked: 36 times
Post by electro_handyman »
I had the same install issue with 7.12
The option to "install to pc" was not available until after the map was updated/installed to the XT 1st.
