MotoMate ZumoLock
pangasuis
Has liked: 8 times
Been liked: 5 times
MotoMate ZumoLock
Post by pangasuis »
so iv been thinking about getting a lock for my zumo because well i was waiting at some lights a skally was looking at my zumo like he was going to steal it and in all rights they are not hard to remove.
anyway i got the MOTO MATE ZumoLock and its worth the money. if u are thinking about getting one i suggest u check these out.
DiavelDes
Has liked: 4 times
Re: MotoMate ZumoLock
Post by DiavelDes »
Do you have a picture instead, does this just cover the release button. How hard is it to remove with this installed.
pangasuis
Has liked: 8 times
Been liked: 5 times
Post by pangasuis »
so its has easy has unlocking the lock and pressing the button on side to release. its very discreet and can hardly be seen.
u basicly turn the lock which turns a little plate that goes up behind the release button so u cant press it.
DiavelDes
Has liked: 4 times
Post by DiavelDes »
Gotcha cheers.
