Have been using a 550 that I bought used for a number of years. Has worked well, even tho' I have had to replace the screen / digitizer a couple of times, internal battery, and eventually the keypads.
Anyway, had a question to see if there is a way to alphabetize the favorites list. Sure would make it easier to find a location, even if you don't remember how you spelled it when you entered it.
Many thanks, and hope to peruse the many topics now that I am here.
New User From Virginia
'95 Kaw Concours (207K), '02 Kaw KLR (60K), '67 Honda CL77 305 Scrambler (15K), '22 900 Ace Ryker Sport (5K and counting)
- Has liked: 148 times
- Been liked: 455 times
Re: New User From Virginia
Greetings from North Carolina. Welcome to the forum!
I don't know about the 550 but know that the XT sorts based on distance from your current location. I am not aware of any option to change that. I might be worthwhile to post the question in the forum dedicated to the 450/550.
Appreciate it. Figured I'd introduce myself here first with my question, then move it to the 550 board if nothing popped up here.
Thank you again.
Thank you again.
- Has liked: 432 times
- Been liked: 952 times
Too long ago for me to remember, but they may be displayed in order of distance from your current location.
[edit] Sorry @Peobody. Using my smartphone - I didn't read through the previous posts. You had already said exactly the same thing !
Well poo!!
That's exactly how they are presented (by increasing mileage). Never noticed that before, and if I did, it just didn't register.
Thank you both.
Thank you both.
