Hi guys
I bought a genuine Zumo 590/595 car mount on ebay,its in the box unused but It didnt come with a charger cable,I have several car chargers but any cable I tried in the mount wont fit.it's different to the cable that plugs into the 590 unit itself...could anyone tell me the type of cable I need or is it garmin specific
thanks
John
Zumo 590/595 car mount cable?
- Site Admin
- Has liked: 438 times
- Been liked: 266 times
Re: Zumo 590/595 car mount cable?
jdh1340
I have a Garmin 590 car mount too. The plug in on it looks like a USB Micro but they do not fit, neither do the Mini. It, at least mine, requires a special cable. Mine has what appears to be a plug that is similar to a USB Micro but is slightly larger and cigarette outlet style plug on the other. The part number for mine is Garmin Model: 010-12110-02.
I hope this helps.
I hope this helps.
Zumo 590
Montana 610
Drive 60
inReach Mini
Montana 610
Drive 60
inReach Mini
thanks ZFtracker...your part number was correct..all sorted now....cheers
