Heat seemed to afffect my XT
On the last day of my recent trip I stopped for lunch and stowed the XT in a fairing pocket rather than the trunk where I normally put it. I pressed the power button before putting stowing it which I normally don't do. When I took the XT out of the pocket ir was hot to the touch. I then could not get it to power up, not by putting it in the cradle and starting the bike nor with its power button (long holds and repeated short presses). When I got home I brought in the house and let it sit while unpacking, starting laundry, and washing the bike. When I returned to it several hours later it started up with a long hold on the power button. All seems fine with it. I have ridden with it in +100 degree temps without a problem so am really dumbfounded by this failure. Has anyone experienced similar?
Fallguy67
- Has liked: 45 times
- Been liked: 4 times
Re: Heat seemed to afffect my XT
According to the the manual, the Operating temperature is a range From -15° to 55°C (from 5° to 131°F)
Depending on the outside temperature, I could easily see it getting above 131°F in a small compartment.
I haven't had this problem with the XT, but I have with my phone, just from direct sunlight if it is in it for too long.
Exceeding 131°F is a real possibility. It was on the cradle during the ride home and never started up so there must be something that prevents auto-startup from external power even after cool down.Fallguy67 wrote: Fri Sep 23, 2022 1:57 pm According to the the manual, the Operating temperature is a range From -15° to 55°C (from 5° to 131°F)
I noticed that after tucking my XT into my fleece chest pocket over lunch, that it came out VERY sensitive to anything that came anywhere close to it. It returned to normal in about 5 minutes - by the time I was ready to move off.
- Site Admin
- Has liked: 438 times
- Been liked: 265 times
My ghosting issue would only happen when the unit got hot!
was fine if it had airflow but as soon as it got hot all sorts of strange things happened
It was exchanged for another one
