The software is just appalling. Sure it has a good screen and you can turn your central heating on with it
I bought it because the nature of the ad implied it could do offroad but it clearly cannot with the installed maps as it can only show tracks and if you try and do a trip planer it just bugs out as obviously the map doesn't have some of the route displayed on the map.
Tbh I can do this with a cheap modded Chinese sat nav running OSM maps. I am quite adept at off road mapping but this Zumo effort is in a class of its own in glitchy poorly thought out software. I know this works as I navigated half of Europe on road with a £26 sat nav taped up and sealed behind the screen of my Blackbird running navigator11 and OSM maps. The same system I modded to use on my dirtbike. Its shows lanes okay but navigating involves too much OSM mapping tweaks as you have to do that to get the sat nav to recognise the legal lanes but then some dullard comes along later and reassigns the lane to a footpath again. Basically I gave up.
As for the Zumo
When connecting with Garmin Drive because the piece of junk can't communicate directly with Garmin Explore (who the hell designed this feature,,a chimp?) it frequently has to think about it or doesn't connect at all. It will show on my phones bluetooth but heyho will it work sometimes? Will it ****.
After turning off and on eventually you can get it to do that and occasionally it even manages to sync with explore except often if you wing across a gpx file well it might show up but clicking on it then says it doesn't exist
So that doesn't really work so well, one minute is does then it don't. Full marks for trying to make it wireless but zero for execution. I have reset the thing which has deleted all the stuff I put on i and also removed everthing from Explore otherwise it will try and resync if I reconnect again but am seriously thinking of giving up and sending it back
I am within my 30 days so Garmin have okayed this, I haven't used it as such other than tried to set it up. They suggested I buy a Montana 700 or something else can't remember what I was too busy laughing that was marginally cheaper at £499. Really? I rather stick pins in my eyes.
So connect to the PC and use Basecamp
What a fiasco. Most of the time it doesn't show on the Basecamp. it might after about 5 mins if your lucky, my guess is if you have Garmin drive and explore and bluetooth on at the same time the software throws a wobbly. Bad programming?
So after the reset I may have one more try but really feel I am flogging a dead horse with this. It quite simply doesn't fit the bill.
Any thoughts before I return it?
