I'm having a bit of an issue.
When I boot up the 595LM everything is fine, I get my motorcycle icon but not much else map wise. Zoomed in and out made no difference. I recently been to Portugal MotoGP and it worked fine.
I have updated it made no difference.
Anyone had this issue?
Zumo map display issue
- Has liked: 13 times
- Been liked: 33 times
Re: Zumo map display issue
Make sure that the map has been selected.
Michael S.
Trinity, North Carolina
- Has liked: 60 times
- Been liked: 146 times
All I can think of:
Make sure only one map is selected, preferably City Navigator.
Try changing themes.
Try hardware reset.
Re-install map.
Try hardware reset.
Re-install map.
It's sorted now thanks for the advice.
I still don't know why the map went bad.
For some reason it would not update my Zumo 595 unless there was a permanent power to my laptop.
I updated all my Garmin's while I was using the updater: Garmin 66W, 46 Dash cams, Nuvi 2598 & Zumo 550 nothing to update on this unit
