Cradle Lock for 660 Mount
- kernowing
- Has liked: 135 times
- Been liked: 61 times
I made this simple device to act as a detterent. As seen in the photos it prevents the release button being pressed meaning the Zumo or dust cover cannot be removed from the cradle. It also prevents the GPS from being accidently released while you're travelling. Seems unlikely but I have heard of it happening at Motorway speed
It obviously would not stop a determined thief but may stop someone taking the unit if you leave it on the bike whilst paying for fuel. (I've heard of that happening as well)
2007 GL1800 Goldwing
Zumo 660LM
Zumo 660LM
- Site Admin
- Has liked: 438 times
- Been liked: 265 times
Re: Cradle Lock for 660 Mount
I have seen people use a tie wrap before today in a similar way
The only trouble with that is you need to carry snips with you and tie wraps
i bought something like that off of shapeways for a few bucks. it has a little locking tab that makes it a pain to remove and it's pretty hard to see behind the unit. for me its actually easier to pop the unit off than put on or take off the tab at short stops tho.
- kernowing
It's never gonna make it thief proof Alan but when it's clipped in place it should (hopefully) deter someone who's not familiar with the release button. If nothing else, it will stop accidental release from the cradle when on the move.
Zumo 660LM
Zumo 660LM
- dave726
- Has liked: 5 times
- Been liked: 8 times
Keeps mine from falling off the cradle. Easy to remove and put around my wrist while inside a quickie mart. More secure than a cradle lock that a 1" prybar may unlock.
- dave726
Self-stick zip-tie mounting tab. I saw something similar years ago that someone posted. The finger hole in the boot lace was my idea as it makes it faster to loop securely over cradle and down to the bottom ball socket on my handlebars before snapping the Zumo into the cradle. Tight fit around my wrist, but that's good so it doesn't slip off. The front side has a RBNS HOODS $30. to cut down on sun glare.
