Synchronisation with Explore Cloud is not working with new Firmware 4.30
lpop
Post by lpop »
Today i installed the new Firmware 4.30. Also the Tread App on the iPhone got a new update.
Now the Synchronisation is not working anymore.
New Tracks from the explorere Cloud will not be transfered to the XT2.
Does anybody has the same problem?
Thx lpop
dhwalt
Re: Synchronisation with Explore Cloud is not working with new Firmware 4.30
Post by dhwalt »
Try a full reset on the XT2. You will have to re-enter your preferences but this solved a lot of my issues following the update.
Dave
lpop
Post by lpop »
A full reset didn‘t help. Also a rollback from 4.30 to 4.00 didn‘t help. Seems the Tread App with version 2.07.33 is the problem.
turbo19
Has liked: 100 times
Been liked: 23 times
Andorra
Post by turbo19 »
There is a Tread update coming soon (Garmin words).
Meanwhile you can install 2.06.22 version by this web (june "stable" versión).
https://apkcombo.com/es/tread/com.garmi ... app.tread/
Regards,
jures
Slovenia
Post by jures »
No issues with me, also with iphone
PedroBrennan
Post by PedroBrennan »
Meanwhile, you can install version 2.06.22 using this website.
https://gamemodfree.com/games/aksi
