Power button
For everything Garmin Zumo 345/350 related
copycat73
Power button
Post by copycat73 »
Hi one and all ,
just a quick one ...the rubber power button on my 340 has fell to bits,
would any one know where i could buy a replacement ?..
tia.
MSTOCK27370
Has liked: 22 times
Been liked: 44 times
Re: Power button
Post by MSTOCK27370 »
If you are in the USA, (N.A.?) send the device to PalmDr.com - Palm Doctor. They have repaired many of my Garmin GPS devices, screens, batteries, power buttons. Reasonable cost, and excellent work.
Michael S.
Trinity, North Carolina
copycat73
Re: Power button
Post by copycat73 »
bit far as im in the uk.
copycat73
Re: Power button
Post by copycat73 »
update.. i did contact PalmDr.com .. not so much as power button.... as a tablet :|
pepgra
Spain
Re: Power button
Post by pepgra »
I am a 3D printing enthusiast and have been able to design this for everyone.
https://makerworld.com/en/models/659875 ... eId-587018
a cordial greeting
Re: Power button
If you still have the button, and it is the joining membrane that has disintegrated you can tape over the hole on the back, fit the button from the inside and glue it with some flexible glue. Eg uhu extreme repair. Careful not to get it on the back of the button - just down the sides. There will be enough movemnet onnet in the button to activate the micro switch on the circuit board.
Then remove the tape when it has set.
