A mate of mine came round today to transfer some routes to his Nav V. When plugged into the laptop it showed Internal Memory and Memory Card
I couldn't see a memory card slot. Would I be right in thinking that to Nav V is split into two drives with one of them named "Memory Card" but is not really a memory card. Or is ther a hidden compartment I didn't find?
A question for the wise ones
- Has liked: 71 times
- Been liked: 191 times
Re: A question for the wise ones
The SD slot is inside the battery compartment. Unscrew the cover, move/remove the battery, and it will be on the inside wall nearest the electrical contacts.
https://www.youtube.com/watch?v=iFJxsr_OCzc
