Email notifications have stopped
Need help with the forum? or got some forum feedback? Please use this section.
Hi Stu,
I am no longer receiving email notification of replies and new posts to subscribed forums. I dug through the User Control Panel options and found the option for replies notifications. The email option was unticked on it so I re-enabled it and it is now working. Where is the option to enable email notification of posts to subscribed forums?
Been liked: 266 times
Re: Email notifications have stopped
You may need to re subscribe to them
if you click on the user control panel on the first page there is a link to show what you are subscribed to
I am not sure why this has change for you as noting has changed with the software :?
Thanks Stu.
My subscribed forums appear to be listed correctly in the User Control Panel. I will look into re-subscribing.
Just to be clear, are you saying that there is not a setting that enables email notifications of new posts to subscribed forums?
Peobody wrote: Thu Nov 30, 2023 7:36 pm Thanks Stu.
if you are already subscribed then you should be getting emails already
if not then it can be enabled in this section
Screenshot 2023-11-30 204943.png (34.04 KiB) Viewed 8407 times
