Route Difference
Sandrider
Ireland
Route Difference
Post by Sandrider »
Hi all
I am planning a little trip around Europe in the summer and I have or thought I had all the legs of the route sorted but today when having a proper look at each leg I found a difference on the leg going from Lake Garda to Trafoi. On the mobile tread app the route is as i want it but on the Garmin XT2 the route wont go over the Stelvio to Trafoi it is sending me left at Bermio and then on a big detour around to finish in Trafoi from the other side. Is it some setting I need to Change or is it a compatibility issue between the phone a Galaxy A14 and the Garmin XT2.
It is not the fall that hurts, its the sudden stop
Has liked: 337 times
Been liked: 366 times
Re: Route Difference
Sounds like it may be a seasonal road closure as that often causes issues in mountainous areas?
Sandrider
Ireland
Post by Sandrider »
Thanks for your reply👍 I had forgot about the winter road closures.
