Maps not updating on a 595
Has liked: 116 times
Been liked: 82 times
So after installing the latest Garmin Express and then installing CN EU 2025.10 NTU on my 590 the 595 I own doesn't show that there's an update for the 2024.20 maps on it, same laptop and USB lead :?
Any ideas on how to persuade the 595 to update to the latest maps?
Edit 1 - tired another cable with the same result.
Has liked: 356 times
Been liked: 374 times
Re: Maps not updating on a 595
Try deleting the 595 from Express then add it back
sussamb wrote: Sun Mar 03, 2024 7:55 pm Try deleting the 595 from Express then add it back
Unfortunately that hasn't worked.
An oddity I see is that the 595 icon in Express (7.20.0.00 but also in previous versions) doesn't look like a 595 when the other products do look like they do in reality.
Well provided Express recognises it the icon won't make any difference. May be worth contacting Garmin ... 0808 238 0000 or https://support.garmin.com/en-GB/?conta ... tab=topics (scroll down to bottom for options)
Has liked: 105 times
Been liked: 231 times
Wait a couple days and try again. I've had this happen on both a 595 and an XT.
biz
Has liked: 22 times
Been liked: 23 times
Post by biz »
I've updated three 590 (all with 595 firmware) to the new maps happily, but I'm still on GE 7.19.0.0 (which GE claims is up to date, so maybe there's a problem with 7.20 as I'm not being offered it...)
biz wrote: Mon Mar 04, 2024 10:39 am I've updated three 590 (all with 595 firmware) to the new maps happily, but I'm still on GE 7.19.0.0 (which GE claims is up to date, so maybe there's a problem with 7.20 as I'm not being offered it...)
Exactly. In the past, folks would post about an available update but my devices wouldn't acknowledge it for several days afterwards. Be patient, try once per day and don't stress. It will come along eventually.
I called up Garmin UK support and apparently my 595, bought second-hand, has a "travel edition" maps ie worldwide and so the CN EU maps are not the only ones when I update it, so it'll be a different update to the 590 etc I have.
Looked on Basecamp and see no difference between the CN and the 595's maps, but a quick google seems to say the Travel Edition can download other maps for free. Never heard of that before!
Correct but you can only have 2 of the 5 (I think) installed at one time. To install another you have to delete one.
biz
Has liked: 22 times
Post by biz »
sussamb wrote: Mon Mar 11, 2024 5:54 pm Correct but you can only have 2 of the 5 (I think) installed at one time. To install another you have to delete one.
My 590 (with 595 firmware) isn't a Travel Edition (in fact, I've never heard of those!) but I have 3 regions (Europe, North America, Australia and New Zealand) installed on it.
