Partial screen freeze up.
My 396 speed icon and trip arrival time freezes up intermittently. Is there a way to reboot the system?
Re: Partial screen freeze up.
Sorry I do not have your Zumo model
But on the XT there is an option under Settings ->Device ->Reset
On the 590 and 595 and XT there is an option in a hidden system menu.
View Map -> Speed button -> Long press the circular speed (10 secs) -> Clear All User Data
Worth a try ?
Worth a try ?
Did this work @Purrtec ?
Or have you found a way that does work ?
To,jfheath,
My 396 has the same settings as the XT. I did the reset and so far I haven’t had a freeze up, but it was an intermittent problem.
It seems to have worked to this point. I will repost if it happens again. Thank you, purrtec.
