Adding Symbols to your route and create collections
Emile
Post by Emile »
Hi guys,
As a former TomTom 550 user, I finally made the step to the Garmin Zūmo XT2. I have figured out some stuff and on request (dutch forum) documented it on my website. Please read if you're interested:
https://www.bumabuma.nl/motor/zumo_xt2.php
Warning: This is my way of working (without Basecamp)! Everybody has his own preferences!
I have also created a tool to get the most out of my Garmin (still extending) and this might be useful for others.
By adding some additional info in my routes in MRA and by naming the GPX files correctly, I can create one GPX containing all for a daytrip. By importing via Tread App it creates a nice collection per day.
https://www.bumabuma.nl/motor/zumo_xt2_poi2pic.php
Example output (shown exactly so on the XT2):
I am happy to receive some feedback!
Emile
Re: Adding Symbols to your route and create collections
Post by Emile »
Nobody tried it?
Am I the only one with this need?
Emile wrote: Thu Mar 28, 2024 9:46 am Nobody tried it?
You may be.
I prefer cleaner & simpler routes. Your map already look cluttered to me in your posted map screenshot, I can't imagine stuffing all that onto a small gps screen. I like to delete more of the symbols and labels for when I zoom in. I'm also not the type that has to have everything labeled in detail. What pops up on the top of the screen for the next point is fine for me as I don't plan break spots or view spots or refueling spots. I'm more of a "follow my planned route and stop when I feel like it or have a need to" like refueling. I don't need/use Bird's Eye. And I hardly use POI or waypoints.
As you say, "Everybody has his own preferences!" You've found what works for you, stick with it! Me? I find Base Camp to be the simplest and most straight forward routing software available. No jumping through hoops to "make it work". For me, less is better!
Emile
Post by Emile »
Thanks for the reply! Appreciated!
The screenshot is just an example of the possibilities. Normaly a daytrip has only a few POI's that only popup when you're nearby. The refueling icon I am only using when riding very remote like Scotland Highland, because you get in to trouble if you don't refuel in time...
fjb2022
Post by fjb2022 »
Looks very interesting - I've just got my XT2 but will stay with MRA for route planning so I'm going to check POI2PIC out - thank you 😊
Johnsondvr
Has liked: 4 times
Post by Johnsondvr »
This looks interesting. I use MRA for all my planning and I like the icons that are available for use with different waypoints. Just bought myself an XT2 and will have a ‘play’ with your POI2PIC tool.
Thanks for posting here.
