346/396
tojjer
Has liked: 25 times
Been liked: 20 times
Post by tojjer »
My 346 seems to be getting updated via GE nearly every time I plug it into the pc to transfer routes.
Is it just mine, or is everybody else with one of these getting them?
At first I wasn't sure if it was the same update not installing properly, but it always says software updated after a minute or so.
Sleuth
Has liked: 14 times
Been liked: 16 times
Belgium
Re: 346/396
Post by Sleuth »
Do you have the Cyclops Subscription?
It seems as if the new models have a subscription for the Safety cameras included. Or at least the 296 & 595 have.
You can check what updates it is installing by clicking on "View Details" when looking at the particular GPS.
Updates Available Notice:
595 Updates Available.JPG (19.35 KiB) Viewed 4208 times
View Details Selected:
595 View Details.JPG (20.47 KiB) Viewed 4208 times
Maps: Europe NTU 2024.10
tojjer
Has liked: 25 times
Re: 346/396
Post by tojjer »
It doesn't come up in the update available, but the Cyclops is available to download under the subscriptions tab
I assume that this means it's not insatlled but I can download and install which would incur additional costs?
Sleuth
Has liked: 14 times
Belgium
Re: 346/396
Post by Sleuth »
tojjer wrote: Sun Oct 21, 2018 12:27 pm It doesn't come up in the update available, but the Cyclops is available to download under the subscriptions tab
I have had that as well. I just clicked on it to install it, and it worked without it asking for money.
Not quite sure why it decided that it was not already installed, but it was installed without an issue. I would presume that if you need to pay for it, it would ask you before you installed it.
Best regards
Sleuth
tojjer
Has liked: 25 times
Re: 346/396
Post by tojjer »
Thank you. I will press the button and report back on whether it asks me for money
tojjer
Has liked: 25 times
Re: 346/396
Post by tojjer »
Well, installed it. It didn't ask for any money so I assume it's as you say and part of the purchase when you buy a new Garmin
