Does the Zumo XT track miles?
budweizer
Post by budweizer »
I'm interested in buying a zumo xt for my Honda XR650L adventure/single track bike. I ride probably 80 street 20 off road. I bought a set of black KKE wheels and now I lost my mechanical speedometer. I have been running a trail tech vapor for a few months but it might be a defective unit because it does NOT keep mileage. After every ride the odometer resets. I always wanted a Zumo XT but to justify it I would like to know if it also works as a Odometer or if there is an app I can get on the Zumo that would be an odometer?
Thanks
MotoToph
Has liked: 28 times
Been liked: 15 times
Re: Does the Zumo XT track miles?
Post by MotoToph »
The Zumo shows your speed.
ZUMO XT
K1600GT
Has liked: 109 times
Been liked: 252 times
budweizer wrote: Mon Mar 18, 2024 2:03 am I'm interested in buying a zumo xt for my Honda XR650L adventure/single track bike. I ride probably 80 street 20 off road. I bought a set of black KKE wheels and now I lost my mechanical speedometer. I have been running a trail tech vapor for a few months but it might be a defective unit because it does NOT keep mileage. After every ride the odometer resets. I always wanted a Zumo XT but to justify it I would like to know if it also works as a Odometer or if there is an app I can get on the Zumo that would be an odometer?
Thanks
Yes, the XT will act as an odometer. It has 2 separately reset-able "distance traveled" parameters. They do not reset until done manually or maybe when a master reset is done but I've never done one. I routinely use Distance Traveled A for daily mileage and B for cumulative mileage over the entire trip.
MotoToph
Has liked: 28 times
Post by MotoToph »
I don't know why I read speedometer. 😂 Sorry 😐
ZUMO XT
K1600GT
