Resolved computer install failures for universal maps.
Resolved an issue with third party maps failing to download.
My comment:
This is the fourth 7.20.x release in 15 days. The last three only contain fixes. Thanks Garmin for quickly releasing patched versions but I would be embarrassed to admit to being a Garmin developer.
Problem is that Express works for all it's On the road and On the trail devices, its original task replacing MapUpdater, and then went on to work with all of its watches, marine, cycling, fitness devices etc.
Testing every possible combination, together with all the numerous PCs and Macs, and the multitude of their operating systems, is simply impossible but the team tend to react promptly when issues occur, and many of the updates will have nothing to do with Zumo users.
I always felt Garmin should have stuck with MapUpdater, and then created other programs to interact with the watches etc, but that's not the route they chose.
sussamb wrote: ↑Thu Mar 21, 2024 7:54 pm
I agree with that. I seems an impossible task to test each version of Express with every device potentially in use. An Express version for each device category would make more sense.
The trouble with that is the time to develop it for each version.
It's all about profits these days so the less they can do in one go the better for the profits
We are also the beta testers these days! They release it we use it and find and report the bugs and they fix it and create another issue! It's the circle of life for software
