Hi all,
I have been planning routes for my Zumo 346 using all manner of things to try and find something that actually does what I want it to do.
So far I have used Basecamp, MyRouteApp, Tyre, GPX Generator and even the trip planner on the unit itself.
The problem I am getting, is when I am following a pre planned route, and for whatever reason ( road closure ? ) leave that route, the Garmin does not reroute me back to the planned route. I have tried the skip next destination/waypoint button under the change route icon, but some times it doesn't give me this choice.
I have aslo tried the detour/detour via distance/detour via road choices. Nearly every time, all of those just send me straight to the end destination again.
I had a 3 day trip to Wales recently and we came across a road closure which took us way off our route. We had to stop and use a map to see how to get back to our route and the places we wanted to go via.
Basecamp seems to give me a better choice of the "skip next waypoint/viapoint/destination", although it does try to send me back on the route to hit one that I obviously didn't tell it to miss
MRA seems to be the best at carrying on once I do actually rejoin the planned route, but again will send me back at times
Have any of you found the same problems, and if so, how do you/did you rectify it when you leave a planned route?
Cheers
Planned routes (again)
- Site Admin
- Has liked: 438 times
- Been liked: 266 times
Re: Planned routes
I have found that if you use any program other than basecamp then the results can be a bit random!
I have also found that if you only have a couple of shaping points/waypoints then when you skip one the routing to the next can be totally different
What I tend to do is add a fair few shaping points so if I do skip one or two then I don't get routed totally different
I use a zumo 590 with automatic calculation set to on
tojjer
- Has liked: 25 times
- Been liked: 20 times
Re: Planned routes (again)
Thanks Stu. That's interesting you have the recalculate set to ON. Mine just automatically routes me to the end destination with that on.
I will try it again with a lot more shaping points, although I thought I had plenty on the roads I particularly wanted to ride on.
Cheers
Cheers
- kernowing
- Has liked: 135 times
- Been liked: 61 times
Re: Planned routes
If I understand you here Stu--if you have Auto re-calculation ON, the Zumo will return to the original beyond the point where you've gone off-route and the Zumo will re-route to hit the remaining shaping points?Stu wrote: Thu Oct 25, 2018 8:30 pm I have found that if you use any program other than basecamp then the results can be a bit random!
Would that be correct for the Z660 as well?
2007 GL1800 Goldwing
Zumo 660LM
Zumo 660LM
- Site Admin
Re: Planned routes
Yes thats how it seems to work on mine although I'm not sure how it would work on the 660 I suppose there is only one way to find out and plan a route on roads you know and see if it does as expected with rerouting on and skipping a waypoint/shaping pointkernowing wrote: Fri Oct 26, 2018 10:26 amIf I understand you here Stu--if you have Auto re-calculation ON, the Zumo will return to the original beyond the point where you've gone off-route and the Zumo will re-route to hit the remaining shaping points?Stu wrote: Thu Oct 25, 2018 8:30 pm I have found that if you use any program other than basecamp then the results can be a bit random!
I must say though it does reroute to the next shaping/waypoint and this can be different from the intended route depending on how far off route you go
