Data on Tread , then appears on both XT2 and online at Garmin Explore
Does anyone know the sequence re XT2 next or Explore next ?
Is XT2 getting its data from Tread or Explore ?
Tread data sequence ?
- Has liked: 350 times
- Been liked: 748 times
Re: Tread data sequence ?
My understanding was that Tread and Explore both sent their data to the Explore database. I can't imagine that would be done on a rota. Computers usually talk using a semaphore basis "Oi you, I need some attention", rather than a polling basis ("Do you need owt ?", "Do You ?", "How about You".....)
Of course, my understanding may be wrong.....
