It might be me
It might be me
I have just started to try and get to grips with BC
I successfully installed the latest map into my 346 using GE, but as the first install crashed out I tried again and I think I did not select update
So I have been trying to unlock the map online but it is driving me nuts
I can get the serial number
I can get the Product Key
I can get the Unit ID
But I cannot add the unit ID as there appears a "No Entry" sign and the data entry field is locked!
This my screen for Basecamp
Re: It might be me
OK
So I tried with BC and felt I was banging my head against a brick wall..
The screen shot above showed the map to be something "Stick Man" would be happy with.
Item 1 is a comms error to the Zumo.
Item 2 suggests that the roads around Cromer are in the Tidal Zone (Let's not get started on that subject or I'll kick off the "Crab Wars" again
So, being a slow day at work, like really slow... I uninstalled all the Garmin s/w from my creaky old laptop and from being logged in on the Garmin website and having Zumo connected I re-installed BC.
Now where is the" tooting trumpet" emoji when you need it!
BC has the up to date map, unlocked. Good enough to make sense although a lot of the data around my town that I know, is waaaay out of date.
So being as it was still a slow day at work. I then started to build up some way points and try out a couple of routes that I ride regularly. Having remembered the tutorial from here and blundered my way around settings etc. I can now create a pretty acceptable route in not too long a time.
I then transferred them to the Zumo\Memory Card\User Data and got the Green tick.
So this is where the "Deflating Balloon" emoji is required.
Exit BC and eject the Zumo from creaky old laptop and the start up Zumo.
Err. Wheres my way points and routes?
Hmmm...
Right. Slow day at work is finished. Time to head off for "Dunna" and a pint of "Heavy"
Still. I'm making progress
Hmmm...
Re: It might be me
Not sure. Why not send them to your device instead of the card? Either way do you need to import data into your device or does the import happen automatically? If automatically you may need to give it some time to import the data.
- Has liked: 119 times
- Been liked: 267 times
Re: It might be me
No worries, sending data to the card is the only way I've done it for 10+ years. I NEVER put data on the device. But, depending on the device you have, it may be important how you put the data there. I discovered a problem when my 595 was new- it doesn't like to have data moved to the card using the transfer command. I simply drag and drop the data to the User Data memory card. You then have to find on your device the Import command. It's usually under Tools or something similar. Pick Import, check the boxes of what to Import and Go/Save.
Re: It might be me
Thanks for the replies folks.
Ok, so it's gradually coming together.
Just a couple of things I haven't got pinned down.
Probably the first is the transfer to the 346 from BC.
If I use "Send To Device" and select "Zumo 346" (that is the device memory) then my new route is detected, and the Zumo User Interface asks me to import the new route. So far so good.
If I go through the above and send it to the memory card, then it is not recognized at all.
I have been through the 346 UI looking for anything that refers to the memory card. So far not found anything.
So if any 346 owners out there know the way to access the memory card from the Zumo UI.....
Re: It might be me
Step by step, one at a time.JimKat2 wrote: Fri Nov 16, 2018 11:43 am
Thanks for the replies folks.![]()
1) When you plug your zumo into your computer and open Base Camp, on the left, are you seeing your device and your memory card listed separately? I've attached a picture below showing mine, I would expect yours to be similar.
sussamb brings up a good point about formatting but we'll get to that. In newer zumo models card formatting on a computer is not required, the zumo does it when you insert the card. Plus, I found out that FAT32 formatting is kind of old hat, my relatively new laptop doesn't have that option. So:
2) What other info do you have on the card? Is it anything that can't be easily replaced if a new card is purchased and tried? I'm NOT saying run out and do this yet, just curious.
- User Memory.JPG (14.93 KiB) Viewed 5960 times
Re: It might be me
Right I have some screenshots of my Zumo connecting to BC
As it could do nothing disastrous to my routes waypoints, I opted to re-format the card with FAT32 file format
This first one always comes up
Followed by this one......
So clear the alarms and we have this screen....
Zumo is there with Internal storage and Memory card with Folder <USER DATA> configured.
Sent a route to the memory card <USER DATA> and got the Green Tick on the folder
However when I re-start Zumo it still does not recognise that there is something on the card.
I'll see if I can find a different card just in case the card is at fault.
