What fubction does an SD card serve?
I'm very happy with the Zumo XT and have put many miles on using it. When new I installed a 32 GB card as instructed formatted to FAT 32. Now, 2-3 years later there's nothing on the card other than .System file, Garmin file folder, and Id. 352 KB used, 29.7 free. I would have thought that previous trip data might have been stored in the card but nothing shows. Is this card just for music downloads, or what else does it do?
- Has liked: 140 times
- Been liked: 435 times
Re: What fubction does an SD card serve?
I use it for music but more importantly, to store routes. The XT can modify a route file that is in internal storage but will never modify a route file that is on the SD card. For that reason, some of us prefer to transfer planned routes to the SD card and then use the XT import function to get them into internal storage. Should the one in internal storage get modified, deleting it and then re-importing from the card is a means of recovery.
FWIW, my experience with the XT modifying a route file has been the result of inadvertently changing a route point from shaping to via or vice versa, I don't remember which. This caused a recalculation of the route which included a moved route point and a very different route from what I had created in Basecamp. The route file itself was modified to contain these changes.
I use the SD-Card to store (custom) OSM maps. They can be quite large, and putting them on the internal storage would just not fit.
I also use it to store custom POI (GPI files)
- Has liked: 72 times
- Been liked: 9 times
Peabody said;
“For that reason, some of us prefer to transfer planned routes to the SD card and then use the XT import function to get them into internal storage. Should the one in internal storage get modified, deleting it and then re-importing from the card is a means of recovery.”
Thank you peobody;
- so while navigating a route the XT doesn’t interact with the SD card re the route, correct?
- if I load a route into the SD card, it cannot be used to navigate without loading it into the internal memory, correct.
Thank you, Mickey
Thank you peobody;
Thank you, Mickey
Correct.
Correct. Routes on the SD card must be imported before they can be used for navigation. A value to them being on the SD card is that they remain there for future import. The XT will never touch them other than importing upon request.
- twowheelstom
- Has liked: 100 times
- Been liked: 40 times
i create routes and stuff on Basecamp, then File send to.. to C: drive folder on my PC computer, then copy/paste that file to the SD card on the Zumo, from there I can import to Zumo Internal memory when needed, the reason for doing it this way is for Organizational file structure on the SD Card
2005 Kawasaki 800B cruiser
