Zumo 665 Map Updates
Posted: Fri Jan 17, 2025 2:37 pm
by carolinarider09
I have a Zumo 665 with updated memory to 16GB (Palm Doctor). It currently has 2024 maps. If I plug it in to my computer, the computer recognizes it on Garmin Express but, if I try and up date the maps (it has 2024 maps installed), there are no selections to make. In other words, you cannot up date the maps.
What I did last year was to make a "clone" of the 665's main memory onto. a flash drive. Just in case something happened and I needed to replace the memory.
Yesterday, when I plugged the flash drive in, Garmin Express recognized it as my 665 and also allowed a map update to the 2025 maps.
I thought maybe Garmin had changed the rules about allowing 2025 maps on the 665 so today, I plugged it in to my computer and no updates were allowed.
So, my question is, can I just copy my flash drive to my 665, erasing all the old memory (over maybe just overwriting it)?
If so, has anyone done that with success?
Thanks.
Re: Zumo 665 Map Updates
Posted: Fri Jan 17, 2025 4:10 pm
by danham
It's been a long time since I did this with my 660, so proceed with caution, but I don't think you need to copy everything. I think that the map image files and perhaps the unlock codes should do it. The only time I had to copy everything was way back on a 350 (I think) which I had accidentally formatted.
Posted: Fri Jan 17, 2025 8:33 pm
by sussamb
Think you'll find this is the reason
https://support.garmin.com/en-US/?faq=F ... JG5A1p9tW5
However as you seem to have managed to download to a clone I'd follow danham's advice.
Posted: Fri Jan 17, 2025 9:56 pm
by carolinarider09
Thanks for the responses. I will consider following Danham's advice. I just don't want to take a chance of messing it up.
I guess if I copy the memory contents to another "drive" I could us that for "recovery".
Posted: Sat Jan 18, 2025 6:29 am
by sussamb
@carolinarider09
You may find this useful
http://www.poi-factory.com/node/39231
Posted: Mon Jan 20, 2025 9:54 pm
by carolinarider09
sussamb wrote: Sat Jan 18, 2025 6:29 am @carolinarider09
I think I have done this before. Thanks because I forgot the process.
