I'm having issues with importing a GPX file into the Tread app, I've never had this happen before.
I made a route on calimoto's website and I exported it as GPX, transferred that GPX to my iPhone and when I click "Share" the Tread app is not there, I was like okay let me try directly from the Tread app.
Open Tread -> Saved -> Three Dots -> Import Data (GPX) and the GPX file in my File Manager is greyed out.
Anyone dealing with this?
This is my route
https://drive.google.com/file/d/1zChuxp ... sp=sharing
Importing GPX into Tread - greyed out
- Has liked: 183 times
- Been liked: 166 times
Re: Importing GPX into Tread - greyed out
I email gpx files, produced in Basecamp, and then select the attachment to open a,d my Android phone asks me what app to use. I select Tread and it opens up ok. Might that work for you?
Try my GPX, see if it works for you.Oop North John wrote: Mon Jan 20, 2025 6:46 pm I email gpx files, produced in Basecamp, and then select the attachment to open a,d my Android phone asks me what app to use. I select Tread and it opens up ok. Might that work for you?
Downloaded your gpx to my phone. Went to open it and Tread was one option. See below for what I see it showing.
Hope this helps.
Hope this helps.
- Screenshot_20250121_132429_Tread.jpg (204.65 KiB) Viewed 3621 times
So it's an iPhone bug then.Oop North John wrote: Tue Jan 21, 2025 1:26 pm Downloaded your gpx to my phone. Went to open it and Tread was one option. See below for what I see it showing.
Hope this helps.
The easy bit is working out what the bug is, a whole exponential extra level of difficulty in getting Garmin to acknowledge it and fix it.
Be aware that if you do report it they'll probably want a video of the problem occurring.
Importing with Tread from Google drive worked as a charm. Now it is broken and the gpx file is greyed out, unselectable. Workaround is to enter google drive and the share the gpx file with Tread. Hope it helps.
