I have updated the XT2 maps from Garmin Express but I can no longer find the option to install the maps on the PC.
Does anyone know how this problem has been solved or can be solved?
For me it is important to have the same maps on both the Zumo XT2 and Basecamp.
I have Garmin Express version 7.24.0.0.0 for what it's worth.
Thank you.
The option to install maps from the Zumo XT2 to Basecamp has disappeared?
- Has liked: 127 times
- Been liked: 94 times
Re: The option to install maps from the Zumo XT2 to Basecamp has disappeared?
Have you seen this earlier thread?
TLDR:
Solution #1 - Go back to GE 7.23.
Solution #2 - Have a previous to the XT2 Garmin GPSR, so you can still do it, using the older tech GPSR.
TLDR:
- twowheelstom
- Has liked: 76 times
- Been liked: 36 times
I always thought that you could use Garmin Express of any version without any gps device connected to computer to install garmin maps on your computer only?
2005 Kawasaki 800B cruiser Zumo 396
- Has liked: 136 times
- Been liked: 405 times
I don't think so. AFAIK, it uses the device as validation for the map, perhaps by checking the license on the device??? GE prompts you to plug in a device whenever you try to access anything related to maps without a device attached.twowheelstom wrote: ↑Thu Feb 13, 2025 5:06 pm I always thought that you could use Garmin Express of any version without any gps device connected to computer to install garmin maps on your computer only?
