I need a lot of help from you. I have a Zumo 595 navigation system that I use on my motorcycle but I can't update the map. After Express downloads the map and starts copying it, it says: There was an error installing the update. What could be the problem?
When I try to download it to my computer, it doesn't work. I'm completely at a loss as to what could be the problem
Windows 10 is up to date, Garmin Express is updated. It has a 16gb Sd card formatted to Fat32 and I tried updating it without it. Should I try an older version of Express? Or is there a way to reset the map? It's missing towards Europe unfortunately
Thanks in advance.
