New problem with XT2
Wingider
Post by Wingider »
Hi from the Netherlands,
and yes I have a problem with my new zumo xt2
after using my old zumo 660 for over more then 10 years even with a cracked case, still working it was time to upgrade to the new xt2.
and there the problems start .
During my first ride I noticed there is no line assist. it should be there but is it some where else hidden?
ZFtracker
Has liked: 22 times
Been liked: 39 times
Re: New problem
Post by ZFtracker »
Welcome to the forum, @Wingider.
Zumo 590
Montana 610
Drive 60
inReach Mini
Re: New problem
Welcome to the forum, @Wingider. FYI, there is a specific category for Zumo XT2 questions.
Re: New problem with XT2
Welcome @Wingider - I have moved this thread to the XT2 forums where it will attract more attention. The original will stay in place for a short while.
What is 'line assist' ?
Dutchgixxer
Has liked: 13 times
Been liked: 27 times
Post by Dutchgixxer »
Do you mean Lane assist ? Do you navigate a active route ? Otherwise no lane assist
And you need the City Navigator maps to be visible as the only Routable map.
So no Open Street Map, or OnRoute, should be enabled.
On the XT go to MyMaps, on the XT2 something similar should be available
