XT nach guten 2 Jahren defekt
Goldwinger68
Switzerland
Post by Goldwinger68 »
Hallo zusammen
Ich weiss nicht ob dies schon abgehandelt worden ist. Falls ja, sorryyyy.
Hatte jetzt 2 Garmin XT welche nach zwei Jahren den Geist aufgegeben haben.
Kennt das auch jemand? Für diesen Preis ziemlich unbefriedigend.
Herzlichen Dank für Antworten.
Gruss rolko/Goldwinger68
Re: XT nach guten 2 Jahren defekt
Goldwinger68 wrote: Tue May 27, 2025 6:21 am Hallo zusammen
Hi and welcome.
We are an English speaking forum, so it would be helpful if you would provide a translation with your post - like this.
  • Hello everyone
    I don't know if this has already been dealt with. If so, sorry.
    Now had 2 Garmin XT which gave up the ghost after two years.
    Does anyone know that? Pretty unsatisfactory for this price.
Get in touch with Garmin, complain to them. The XT is guaranteed for 2 years, so if you are just within they should replace it. If you are just over 2 years they may still take pity on you.
Worth a try. Especially if you can back it up with serial numbers.
