HI just recieved my Garmin Zumo XT today
TonyBennett
Has liked: 6 times
Post by TonyBennett »
Just received the unit today and I am not finding it easy to understand. But I am an old guy who isn't up to date with all the technology. Heck don't even have a smart phone! I do have a mobile with big buttons, which I use for emergencies only, and I phone every 6 months to keep the phone number. Why would I want to speak to anyone whilst I am out! :lol: :? Yeah I am an old grumpy sod ;) Just downloaded the software and I will see where it goes from there.
Re: HI just recieved my Garmin Zumo XT today
Welcome to the forums, Tony.
You don't have to use your phone - and if you don't want to use it then do not pair it - because it will install Explore and that will cause other issues on the Zumo XT - in spite of what Garmin ask you to do.
It will work perfectly well if you just pair your headset to the XT - so that you can hear instructions - or if you don't want that then you can follow the map on the screen.
When you put your Zumo XT in the cradle, make sure that the latch snaps shut. Try to pull the top of the XT away from the cradle - to make sure that it is locked in securely. Do that every time.
TonyBennett
Has liked: 6 times
Thank you for the info and details. I know my phone won't link up with anything, its that basic, so not worried it won't link. Just slowly downloading the updates which I need of course. Thanks again
Welcome to the forum @TonyBennett. There is lots of good info and helpful folks here, although many of us can get a bit nerdy. The XT is a nice piece of kit but it has some issues, mostly associated with following routes created externally. If your usage will be to simply have it get you to a destination then it shouldn't be too difficult to figure out.
ZFtracker
Has liked: 22 times
Been liked: 39 times
Post by ZFtracker »
Welcome to the forum, @TonyBennett.
Zumo 590
Montana 610
Drive 60
inReach Mini
TonyBennett
Has liked: 6 times
Thank you for your reply
