Software 6.10
- Has liked: 183 times
- Been liked: 166 times
Software 6.10
Anybody been brave enough to install it yet?
- Screenshot 2025-06-24 202831.png (60.85 KiB) Viewed 2310 times
Dutchgixxer
- Has liked: 13 times
- Been liked: 27 times
Re: Software 6.10
Has anyone with 6.10 installed had Bluetooth problems?
A few times today the sound disappeared, only to reappear briefly and occasionally. Turning off the helmets Bluetooth seemed to resolve it. But then it happened again today. No changes to the XT2 / helmet / phone other than 6.10.
Re: Software 6.10
hi everyone, updated to 6.10 and now all the POI loaded via POILOADER are no more working, or better, only sound without the icons.
Already did a full reset but they are still not working. Tomorrow I will try to contact Garmin customer service ...
Re: Software 6.10
I received a reply from Garmin customer service today. The POI issue is under investigation, but they can't give a timeframe for when it will be fixed. We'll have to wait, hopefully not for too long.Lk77 wrote: Sun Jun 29, 2025 7:46 pm hi everyone, updated to 6.10 and now all the POI loaded via POILOADER are no more working, or better, only sound without the icons.
TheoTiger
- Has liked: 5 times
- Been liked: 7 times
Re: Software 6.10
I downgraded my XT2 to version 5.40. The custom GPI file created with POI Loader does show a custom icon when you click on the “i”.Lk77 wrote: Sun Jun 29, 2025 7:46 pm hi everyone, updated to 6.10 and now all the POI loaded via POILOADER are no more working, or better, only sound without the icons.
However, when I drive past that location, nothing happens — no icon and no sound.
I have reported this issue to GARMIN in the Netherlands.
Re: Software 6.10
I downgraded to 5.40 too, waiting for a fixed softwareTheoTiger wrote: Tue Jul 01, 2025 10:59 amI downgraded my XT2 to version 5.40. The custom GPI file created with POI Loader does show a custom icon when you click on the “i”.Lk77 wrote: Sun Jun 29, 2025 7:46 pm hi everyone, updated to 6.10 and now all the POI loaded via POILOADER are no more working, or better, only sound without the icons.
Re: Software 6.10
Hi guys,
I also have the problem with the lost icons. I was in discussion with the german support but it sees that they don't think they have to do anything as the POI loader is not supported since 2013. They didn't get the point that the problems are caused by the new update.
Hopefully you are right and the other colleagues are working to fix it.
In the meantime I would also like to downgrade. Can you tell me how to do that?
Re: Software 6.10
Check thischrisna wrote: Thu Jul 03, 2025 6:53 pm Hi guys,
https://zumouserforums.co.uk/viewtopic. ... 215#p26215
Re: Software 6.10
Hello,
I've been traveling in France for a week and my device is rebooting every two hours.
I think it's something with the new software because with the 5.40 I didn't get any errors. Is this happening to anyone else?
