Can not close BC
stkm04
Can not close BC
Post by stkm04 »
Hello,
I run BC 4.6.2 on Win 10 Pro.
Sometimes when I want to close BC (by clicking on the X in the upper right corner) the program does not close, it just sits there forever (One time I waited over 30 mins to be sure that it does not close with a delay). The TaksMGR shows the process as Non Responsive, and I have to kill the process.
When I start BC again most of the time everything is ok, however sometimes my last action (e.g. change in a route) was not saved.
Does anybody experience the same problem? If so, have you found a solution?
I have an inkling that it could be because I have zillions of POIs loaded into BC (like all the US Starbucks). But I am not sure that that is the root problem.
Any suggestion would be appreciated.
Thanks,
Stefan
Has liked: 337 times
Been liked: 366 times
Re: Can not close BC
Like any program BC can stall, but it only happens very infrequently for me, Outlook is far more likely to stall :)
stkm04
Post by stkm04 »
Well, for me Outlook works 99.9999%, but BC stalls about 50% of the time. :?
