Railroad Icon always on map screen
denno
Post by denno »
Hi all, for some unknown reason, I have a constant Railroad sign icon on my map screen in the lower left corner that never goes away. This just started happening on my XT2 on my last trip. Prior to that I had only the alerts selected in the Rider Alerts settings and they would only show up at the appropriate times.
I have tried selecting Railroad crossings off and on several times, turning the unit on/off etc. but to no avail. The symbol still appears whether I do a route or just am viewing the map.
Anyone have any ideas on this issue?
Many thanks.
Denno
Re: Railroad Icon always on map screen
I haven't got a clue and am not sure what you are describing, but I'll reply to bump the post.
Can you post a screenshot please ?
benoce
France
Post by benoce »
Salut,
Pendant mon dernier road-trip, j'ai également vue ce panneau en bas à gauche, panneau triangulaire attention train, alors qu'il n'y avait pas de raison qu'il soit affiché et cela pendant beaucoup de kilomètre non-stop, je me suis dit encore un bug ;)
[Moderator]
Welcome to the forum - but please - we are an English speaking forum: Use Google Translate (or similar)
Translation
Hi,
During my last road trip, I also saw this sign at the bottom left, a triangular sign saying "Beware of Trains." There was no reason for it to be posted, and it lasted for many kilometers non-stop. I thought it was another bug.
denno
Post by denno »
Thanks for responding. I do not have it on my screen anymore but am including an attachment of the symbol - what it looked like when it was there.
It always appeared in the bottom left corner of the screen.
I tried every setting I could think of to remove it, but it always remained on every map or route I displayed.
To finally get rid of it, I had to do a Settings/Device/Reset.
After another 6K miles of use, it has not yet reappeared, so I hope the problem is solved.
The issue did seem to appear after riding through 300+ miles of rain where the drops kept bouncing off me and hitting the screen which often registered as me touching the screen. I can't confirm this caused it because I was occupied with navigating the storm, but it seemed to be the time the anomaly occurred and then never went away.
Thanks
Settings -> Driver Assistance - Rider Alerts
Railroad Crossing is one of the options in there. Maybe that it what you need to turn off.
I turn all of these off because they are a distraction.
Please - Let us know if that is what gets rid of them. Or if it doesn't !!
denno
Post by denno »
Turning that option off had no effect - it was somewhat frustrating.
Tried power on/off, RR option on/off etc. in many combinations, still no effect, it was always there until I did a reset.
I of course lost my BT pairings and other preferences, but it did fix the issue.
I guess I'm a little glad to find out I was not the only one to have the issue.
