Map update problems
Having problems with your BMW navigator 6? then please post here with any sat nav, software, mount or cradle problems.
Raf
Has liked: 16 times
Been liked: 5 times
Italy
Map update problems
Post by Raf »
I'm trying to update the maps on my BMW Nav VI. I opened Garmin Express and connected the GPS to my PC.Everything OK.
Express has been stopped for more than 1 hour
“Phase 1 of 2. Preparing your device for map update
This may take up to 1 minute….”
Is this normal?
Thank
Raf
Has liked: 16 times
Been liked: 5 times
Italy
Re: Map update problems
Post by Raf »
Senza titolo-1.jpg (42.27 KiB) Viewed 833 times
No, are you sure nothing is blocking the update? If so I'd disconnect and start again from scratch.
Raf
Has liked: 16 times
Been liked: 5 times
Italy
Post by Raf »
sussamb wrote: Sun Apr 26, 2026 3:57 pm No, are you sure nothing is blocking the update? If so I'd disconnect and start again from scratch.
Yesss! Everything OK.
Thank!!
