Zumo xt frozen
Newmanman
Zumo xt frozen
Post by Newmanman »
Hi , my Garmin zumo xt ( 5 years old ) always worked fine , was out on my motorcycle yesterday and all was fine, parked up and when I came back I turned on ignition and zumo screen was frozen at screen which asks for you to "agree" , despite repeatedly pressing agree it was frozen so did the soft reset by holding in power button for 15 seconds , Unit powered down, came back on but is now frozen at as per image attached, it just keeps coming back to this screen even when I connect USB cable to my laptop
If anyone can help or direct next best action please.
Has liked: 39 times
Been liked: 97 times
Re: Zumo xt frozen
If you also have an SD card in the device, try removing SD Card and trying again.
It's just a suggestion, I don't have any personal experience with this, but testing without the SD card can't hurt, and SD cards can sometimes cause unexplained problems.
Next, you could try rolling back to a previous system SW version (and then updating it again).
Newmanman
Re: Zumo xt frozen
Post by Newmanman »
Thanks, I'll give that a try.
