Just bought a set of these. I have to say, compared to the cheap Chinese ones I had, they are absolutely phenomenal.
The sound quality from the JBL speakers is superb, and it pairs with my Zumo346 in seconds, and my Samsung phone.
Expensive yes, but I bought them for the mesh intercom system.
Off to France early June so they'll get a good test
CARDO PACKTALK BOLD DUO
- Site Admin
- Has liked: 424 times
- Been liked: 241 times
Re: CARDO PACKTALK BOLD DUO
Me too!
I have just replaced my Q3's for some of the features and the difference was worth it for me
I've been using a Packtalk for a couple of years now, and find the bike to bike coms between four is brilliant.
What I have problems with is with the Cardo app and Garmin app on my phone. I'd like to control the Packtalk with the Cardo app via the Garmin, and still have the Garmin on-line features, but having tried a couple of things, I'm fairly sure it won't do that, despite one of the recent Cardo updates being to enable that.
- Has liked: 25 times
- Been liked: 20 times
I watched a video on YT showing how it is best to pair the phone to the PT, and the zumo to the PT, but NOT to pair the zumo to phone.Dusty ST wrote: ↑Fri Apr 26, 2019 10:12 am I've been using a Packtalk for a couple of years now, and find the bike to bike coms between four is brilliant.
I've uninstalled the Smartlink app, and gonna try this way first. Doing it this way, it should allow "Hey Google / Hey Siri" to work with voice activation via the PT, and to still have the Garmin to give directions over the top of intercom/music. That's what I hope anyway.
On my old set up with the chinese intercom, I think it was too much for it cos I used to miss the first bit of the instruction.
Only one way to find out, and that's give it a go!
Yes, that's the arrangement I had with my previous Zumo, both paired to PT, which also allows the PT to be controlled with the Cardo app.
I'll probably go back to this.
I quite liked the idea of controlling the phone via the Zumo.
- Site Admin
I have always had my phone paired to the zumo but I have just paired it to both and phone calls show up on the zumo but are straight from the phone to the headset!
If I have my phone in my pocket I like to know who is calling before I answer so having it displayed is a must for me!
Stu, just out of interest, do you use the Smartlink app, or just pair it straight to the phone without it?Stu wrote: ↑Mon Apr 29, 2019 11:45 am I have always had my phone paired to the zumo but I have just paired it to both and phone calls show up on the zumo but are straight from the phone to the headset!
- Site Admin
I use the smartlink apptojjer wrote: ↑Mon Apr 29, 2019 2:09 pmStu, just out of interest, do you use the Smartlink app, or just pair it straight to the phone without it?Stu wrote: ↑Mon Apr 29, 2019 11:45 am I have always had my phone paired to the zumo but I have just paired it to both and phone calls show up on the zumo but are straight from the phone to the headset!
Any reason why you're asking? Are you having problems?
No, seems to work ok. Had it not connect automatically a couple of times, but for the most part it seems ok.
EDIT: I haven't tried it with the Cardo yet, that was with my cheap chinese one
Because I have a Windows Phone (Lumia 640 running mobile 10), I can't use the Garmin apps (they don't exist for this phone). So I've found that I must use multi-point pairing of my 396 and phone to my Sena SMH5 or they will fight each other. Paired this way, nothing on the phone goes through the 396, but both the phone and 396 can talk to me through the headsets, and I can use Cortana to make hands-free calls.
