Newbie map updates
Pockets
Newbie map updates
Post by Pockets »
Hi, just downloaded farming express and it automatically updated my maps so now i have 2019.20 version 5.0, I’m presuming this is the latest download? I never paid for it it just ask me to choose an area I wanted to update (uk&Ireland) and bingo done , one other thing as soon as I disconnect it from the power supply it turns off is this because the battery’s knackered?
Your comments will be welcome
Has liked: 371 times
Been liked: 380 times
Re: Newbie map updates
Depends on your device, it's the latest map for older devices. As for switching off when disconnected from the PC that's normal on some devices, if it's shutting off without any warnings when you disconnect it from the power on your bike then it probably is a knackered battery.
