Can I use Google Maps to create a route?
Exrm193
Post by Exrm193 »
As above, and then import it to Basecamp??
If so, how?
cheers
mzeist
Has liked: 33 times
Been liked: 31 times
Re: Can I use Google Maps to create a route?
Post by mzeist »
google is maybe possible, but take a look at Kurviger: https://kurviger.de/en
Groet, Marcel.
HarveyM
Has liked: 10 times
Been liked: 9 times
Post by HarveyM »
There's a Maps to GPX website that seems to work;
https://mapstogpx.com/
Rather than 'opening in basecamp' I had better luck saving the file in GPX format and opening that in basecamp.
Another way is described here;
https://www.bedsforcyclists.co.uk/artic ... our-phone/
Google's made it more difficult (you'll need a google account & give them some billing info)
skellum
Has liked: 15 times
Been liked: 5 times
Post by skellum »
I have found this excellent youtube video that describes the process in detail (Mac) might be worth a look
Hope this helps
Has liked: 416 times
Been liked: 229 times
I have learnt a lot off this guy!
but I don't have a mac so I will look for the PC version :lol:
HarveyM
Has liked: 10 times
Been liked: 9 times
Post by HarveyM »
The drawack to this solution (in the video) is that he uses Google’s ‘my maps’ which I find more complex than using Google maps; ‘Maps’ suggests alternate routes and allows you drag way points which are features I didn’t find in ‘my maps’.
Has liked: 105 times
Been liked: 224 times
The one thing I found annoying about Google maps is the limited number of shaping points allowed, 10 I think. If riding across my state at least 3 different routes are required because of this to maintain the route I want instead of being automatically dumped onto an interstate. Base Camp has no such restriction.
Has liked: 347 times
Been liked: 369 times
BaseCamp doesn't but bear in mind your device will have :)
can you not alter the settings in google to avoid interstates? we have a tick box to avoid motorways is that the same?
Stu wrote: Fri Jul 05, 2019 3:06 pm can you not alter the settings in google to avoid interstates? we have a tick box to avoid motorways is that the same?
Don't know about avoidances in Google maps but, being limited to only 10 shaping points severely limits the custom routing. When you use them up Google automatically routes however it wants. I'm currently working on a route in Base Camp, about 370 miles. 10 shaping points are used up in about 80, so another route has to be made, then another, and maybe another. Base Camp will do the whole thing, exactly the way I want it, in one route.
