Dashboards.
alan29
Dashboards.
Post by alan29 »
My old Zumo had the ability to change the dashboard on the bottom of the display in order to show more than just the current speed on the left and one other thing on the right. I like to see arrival time, current time and altitude.
Can't find a way of doing that on my 396. Am I missing something?
Has liked: 381 times
Been liked: 384 times
Re: Dashboards.
Yes, you need to select Spanner bottom right of the map screen then trip data. If that doesn't shown enable it in Settings, map and vehicle, map tools
alan29
Re: Dashboards.
Post by alan29 »
Thanks.
That takes up a lot of the screen, doesn't it. The old Zumos had a narrow bar along the bottom.
