Having recently installed an Autocom system on my bike, I'm confused as to why when I try to "Call Home" in (the 660's phone menu) it tries to connect me to an 04684***** number. My actual Home number is in my phone's contacts list with the correct number. Is there a way to alter this to give me the shortcut to call home?
Thanks, Pete.
Setting "Home" phone number
- Site Admin
- Has liked: 438 times
- Been liked: 266 times
Re: Setting "Home" phone number
That number is probably programmed in to the zumo and will be calling that number and not the one in the phone
- kernowing
- Has liked: 135 times
- Been liked: 61 times
I was rather hoping someone with a 660 could tell me how to delete & replace it.Stu wrote: Sat Dec 21, 2019 10:48 pm That number is probably programmed in to the zumo and will be calling that number and not the one in the phone
2007 GL1800 Goldwing
Zumo 660LM
Zumo 660LM
- Site Admin
I believe that you can add a number to your home location - which is in Tools / My Data / Set Home Location.
Sorry, i no longer have a 660, so I can't verify this, but that is what the manual says.
- kernowing
That's spot on Sir, reset "Home" and phone #. Unfortunately, I tested it shortly after your post and woke the Missus at 01:00jfheath wrote: Sun Dec 22, 2019 12:34 am I believe that you can add a number to your home location - which is in Tools / My Data / Set Home Location.
Thanks for the reply.
Cheers, Pete.
Zumo 660LM
Zumo 660LM
