Hello everybody!
Maybe one of you could help me. I used my new 595LM last summer on some trips. I staked out the trips with custom Google maps, saved them in "My maps," exported them to import into 595. I wanted to go that specific route, but the GPS wanted to live its own life sometimes. This was really tedious since many times I knew that it was not choosing my fixed route. Is there a way to have the GPS go strictly on your fixed route?
Øyvind
Norway
595LM with fixed routes
- Site Admin
- Has liked: 438 times
- Been liked: 265 times
Re: 595LM with fixed routes
Hi and welcome to the forum
You can't just plan routes and export them in google maps unfortunately
- mzeist
- Has liked: 33 times
- Been liked: 31 times
You can have al look and use https://kurviger.de/en instead. There is a learning curve for exporting to a (Gamin) device, but you can have great results.
Groet, Marcel.
- Site Admin
Just gave this a quick go and works well with the right buttons clickedmzeist wrote: Sun Jan 05, 2020 6:13 pm You can have al look and use https://kurviger.de/en instead. There is a learning curve for exporting to a (Gamin) device, but you can have great results.
