A Basecamp update (4.7.0) has been released. However, the link to Google Earth has be removed so if you use that feature you may want to skip this update.
The change history:
Changes made from version 4.6.2 to 4.7.0:
Updated BaseCamp to conform to GDPR requirements
Improved MTP device support
Removed online components of Garmin Adventures
Removed Garmin Cloud Drive support
Removed Garmin Connect find and upload
Removed Picassa photo sharing
Basecamp Update
Basecamp Update
- Sleuth
- Has liked: 14 times
- Been liked: 16 times
Re: Basecamp Update
Thanks for the heads-up.
I will update when I get home.
Maps: Europe NTU 2024.10
Re: Basecamp Update
Damn I updated before I read this! I also use the Google Earth link all the time, I know its possible to export the route to Google Earth but that is quite a convoluted process - does anyone have a link to version 4.6.2?
- kernowing
- Has liked: 134 times
- Been liked: 61 times
Re: Basecamp Update
I've just had a notification offering the update but declined it based on the views of the more knowledgeable members. Just out of interest, where does anyone link Basecamp to Google Earth?
2007 GL1800 Goldwing
Zumo 660LM
Zumo 660LM
Re: Basecamp Update
You have to have Google Earth 32 bit version installed. Within BC click on the View pulldown menu, then Google Earth, and select from three choices of what to view.
- kernowing
Re: Basecamp Update
I've got this installed :- Google Earth Pro 7.3.1.4507 (64-bit) and Basecamp tells me that Earth is not running (even 'though it is)
Is this because it's 64-bit?
Zumo 660LM
Zumo 660LM
