Autocom and Garmin 665
carolinarider09
Has liked: 30 times
Been liked: 39 times
Post by carolinarider09 »
I have an Autocom SPA on my Goldwing. I have my 665 connected to the Autocom via input Aux 2. It seems I have to have the Garmin 665's audio levels near max to hear the Garmin's audio well.
I should mention I am using Ear Inc iPlugz's for listening.
Anyone else have a similar setup?
Has liked: 426 times
Been liked: 933 times
Re: Autocom and Garmin 665
Did you find an answer to this ?
carolinarider09
Has liked: 30 times
No. What I have not done is to increase the volume on the SPA unit. I did not do that because it would also increase the volume of the audio from the Wing's audio.
The only other option is to open the case and determine if I can adjust the volume. The manual is not specific. I do have to verify the GPS is on Aux 2.
