595 locking plate.
595 locking plate.
Hi everyone, just wondering if anyone has tried one. Available on E-bay or at zumoaccessories.com, its called "The affordable zumo security plate". Its designed and made in the UK. Cost is £38.
- Site Admin
- Has liked: 424 times
- Been liked: 240 times
Re: 595 locking plate.
Never tried one but I have seen it!
It's a lot cheaper than touratechs solution that's for sure!
It wouldn't be hard to make one but for 38 quid it's easier to buy it
- Has liked: 129 times
- Been liked: 99 times
Looks a sensible way to reduce the chances of your GPS being stolen when you go to pay for fuel etc. Might get myself one.
- Site Admin
I just send the wife inOop North John wrote: ↑Wed Feb 05, 2020 2:15 pm Looks a sensible way to reduce the chances of your GPS being stolen when you go to pay for fuel etc. Might get myself one.
Well I bought one, had to file the holes out where the fixing screws went, no problem. not a bad lock, but if a thief wants it they will get it but will do damage. So still a good idea to remove sat nav when bike is out of site.
