Unknown points on CN NC 2021.1
I just downloaded 2021.1 to my computer and I have a bunch of unknown points that I can't get rid of. I don't have these unknown points on 2020.3. I have tried every option of what I want to display on the map, including displaying basically nothing and I still have a bunch of these dots all over the place. Any one else seen this or know how to get rid of them. Thanks.
- Has liked: 110 times
- Been liked: 253 times
Re: Unknown points on CN NC 2021.1
Try this griff:
- click your Activity Profile in the toolbar. That's the motorcycling, driving, walking, etc icon. If you don't have one then select View/Toolbars and tick the Activity Profile box. Now click your Activity Profile in the toolbar.
- All the way at the bottom of the dropdown menu, click on Edit Activity Profiles.
- With Activity Profile highlighted on the left side, on the right side click the Select button at Map Display Features/Select features to be displayed.
- Expand each "+" box in the Points section at the bottom of the list. Keep expanding, you'll see. Untick boxes that you don't want shown on the map.
This is how I got rid of all the stupid airplane pictures, too. Explore the other sections some, it'll make sense when you see it.
Hey Russ. Good to see ya. Yep, I have tried that. Actually took out all features and those little unknown dots still showed up. I can 'kind of' get rid of them if lower the map resolution from highest, but they still show up when I zoom in. Weird, because they are not there on the 2020.3 map version.
Don't know what they are. When you hover over them, it says unknown.
Ha! I wondered if "griff" was "griff" down in SC.griff wrote: ↑Tue Mar 10, 2020 12:31 pm Hey Russ. Good to see ya. Yep, I have tried that. Actually took out all features and those little unknown dots still showed up. I can 'kind of' get rid of them if lower the map resolution from highest, but they still show up when I zoom in. Weird, because they are not there on the 2020.3 map version.
Did you dig deep into the menus? I found that at the lowest level if only one box is unticked then the main box is unticked. I had to keep clicking + boxes to way down in it.
Russ - I drilled down and unticked everything and still have these 'unknown' points. Have no idea what they are.
