I purchased a 590LM used. Maps are current and it’s working well. Not my first Zumo (550).
There are no routes in the device and I deleted any tracks that were left in the 590. When I look at the Trip Planner app, there are several trips from the previous owner under the Import button. I can’t find any method to remove these old transferred trips.
How can I remove these old routes?
Used 590 To New User
- Has liked: 15 times
- Been liked: 36 times
Michael S.
Trinity, North Carolina
Re: Used 590 To New User
Look in the GPX folder of your device, delete all the gpx files there then reboot your device. Now use the menu on your device to delete any unwanted data and it should remain deleted.
- Has liked: 109 times
- Been liked: 252 times
this thread, 3rd and 5th posts on pg 2 -> viewtopic.php?f=12&t=95&start=10
Thanks for the assistance. I connected the Zumo to my PC and found one more .gpx file, not sure of the exact name express imports or something like that. Once deleted the trip planning app had nothing at all.
For good measure I did a Master Reset. Started the 590LM all over again.
Michael S.
