Road type
Beacher
Road type
Post by Beacher »
I can't seem to locate the road type ie; curves, hills inthe menu.
I really like this feature when traveling. Please don't tell me they have done away with this.
Be safe
simoncrewe
Has liked: 47 times
Been liked: 38 times
Re: Road type
Post by simoncrewe »
It is now called adventurous routing, once you have selected a destination in 'where to' you are presented with an orange mountain icon with a wiggly line though it. There is a slider displayed also, so that you can set the level of 'adventure' that you would like.
You cannot set road types as such, but you can set to avoid highways/freeways/ interstates in the avoidance menu as before with other units.
Re: Road type
I've seen it when asking it to go to, and in the options it looks like a curvy route is there. But only used it for driving a couple of miles so far, so can't be certain.
Beacher
Re: Road type
Post by Beacher »
simoncrewe wrote: Tue May 12, 2020 12:16 pm It is now called adventurous routing, once you have selected a destination in 'where to' you are presented with an orange mountain icon with a wiggly line though it. There is a slider displayed also, so that you can set the level of 'adventure' that you would like.
I saw that on there. I guess ill have to test it out. I really liked the other way when you could set it individually.
Thanks for the help
