harley gts and zumo 595
- Moose
- Has liked: 3 times
- Been liked: 21 times
I have a 2020 Harley GTS and am trying to get the zumo to feed thru the radio I put the accessory 3.5 mm plug on the cb plug and plugged into the zumo audio out and still no audio to the radio anyone ????
- Has liked: 22 times
- Been liked: 23 times
Re: harley gts and zumo 595
When you say:
"I put the accessory 3.5 mm plug on the cb plug"
You mean the Harley "Audio Jack Jumper" part #69200610 ?
You need to get the Stealership to enable it now with the Digital Tech. Won't work until they do.
There's a good possibility that the flash hasn't been done using the correct settings. I don't know the GTS, but with the GT it isn't obvious which boxes have to be ticked to get it working properly.
