595 sound quality through Sena headset
Tricky1964
Post by Tricky1964 »
I have a 590 whihc has been updated to the 595 firmware (maybe software), i have paired it to my Sena10s, if i use the media player the sound is fine, for directions the sound the terrible, is this a Zumo issue and can i improve it?
Should i revert to the 590 firmware
The intercom and phone clarity is fine.
Any suggestions welcome
JohnnyRidesAlone
Been liked: 10 times
Re: 595 sound quality through Sena headset
Post by JohnnyRidesAlone »
Try connecting aas normal, then disable you BT on the zumo and reenable. It worked a lot of the time for me
tone
Post by tone »
I have this same problem, what do you mean by BT?
yorky
Been liked: 16 times
Post by yorky »
BT = Bluetooth
